Saltar al contenido principal
Panasonic KX-TGE233 Handset Front Panel Assembly Replacement
Qué necesitas
  1. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement, Battery: paso 1, imagen 1 de 2 Panasonic KX-TGE233 Handset Front Panel Assembly Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the handset over to expose the back panel, and slide the panel out to remove.
  2. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: paso 2, imagen 1 de 1
    • Carefully remove the two batteries by lifting up from one end.
  3. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement, Handset Front Panel Assembly: paso 3, imagen 1 de 1
    • Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
  4. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: paso 4, imagen 1 de 1
    • Using a spudger, open the device by starting from the bottom and working your way to the top.
    • This will require some force, so be careful not to break any of the wires inside of the device.
  5. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: paso 5, imagen 1 de 1
    • Once the back has been separated from the rest of the device, carefully place it to the side. Be careful not to completely remove it, however, as there are wires connecting the back to the handset.
  6. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: paso 6, imagen 1 de 1
    • Using the same screwdriver as before, remove the Philips size #00 screw holding the motherboard in place.
  7. Panasonic KX-TGE233 Handset Front Panel Assembly Replacement: paso 7, imagen 1 de 1
    • With the screw removed, the front panel assembly can be separated from the rest of the device.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 2-2, Baechle Spring 2016 Miembro de IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 403
