Introducción
The front panel is a single piece of plastic covering the motherboard, the earpiece speaker, the buttons, and the LCD display. It's the piece that holds the phone together. If you need to replace any of the components inside of this device, or you just want to replace the front panel itself, you'll need to start with this guide.
Qué necesitas
Flip the handset over to expose the back panel, and slide the panel out to remove.
Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
Una persona más ha completado esta guía.
