Saltar al contenido principal
Panasonic KX-TGA600M Speaker Replacement
Qué necesitas
  1. Panasonic KX-TGA600M Speaker Replacement, Battery: paso 1, imagen 1 de 2 Panasonic KX-TGA600M Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • On the back of the phone, remove battery cover.
    • Push down on the marked indentation and pull downwards.
  2. Panasonic KX-TGA600M Speaker Replacement: paso 2, imagen 1 de 1
    • Pull out to remove the battery.
  3. Panasonic KX-TGA600M Speaker Replacement, Speaker: paso 3, imagen 1 de 1
    • Unscrew the two screws on the bottom left and right.
  4. Panasonic KX-TGA600M Speaker Replacement: paso 4, imagen 1 de 2 Panasonic KX-TGA600M Speaker Replacement: paso 4, imagen 2 de 2
    • Separate the front and back of the phone.
    • Store loose pieces for later replacement.
  5. Panasonic KX-TGA600M Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the speaker housing.
    • During reassembly, solder the wires onto the speaker housing. For information on soldering, please refer to iFixit's soldering technique guide.
Conclusión
Kaleb Barquera
Miembro Desde 01/31/17
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 660
