Saltar al contenido principal
Panasonic KX-TGA600M Keypad Replacement
Qué necesitas
  1. Panasonic KX-TGA600M Keypad Replacement, Battery: paso 1, imagen 1 de 2 Panasonic KX-TGA600M Keypad Replacement, Battery: paso 1, imagen 2 de 2
    • On the back of the phone, remove battery cover.
    • Push down on the marked indentation and pull downwards.
  2. Panasonic KX-TGA600M Keypad Replacement: paso 2, imagen 1 de 1
    • Pull out to remove the battery.
  3. Panasonic KX-TGA600M Keypad Replacement, Keypad: paso 3, imagen 1 de 1
    • Once battery is removed, use the Phillips #00 screwdriver to remove the two silver screws at the bottom left and right corners on the back of the phone.
  4. Panasonic KX-TGA600M Keypad Replacement: paso 4, imagen 1 de 3 Panasonic KX-TGA600M Keypad Replacement: paso 4, imagen 2 de 3 Panasonic KX-TGA600M Keypad Replacement: paso 4, imagen 3 de 3
    • Pull the phone apart. The plastic opening tool may be needed.
    • The clear light piece will fall out, so make sure you place it next to the screws.
  5. Panasonic KX-TGA600M Keypad Replacement: paso 5, imagen 1 de 3 Panasonic KX-TGA600M Keypad Replacement: paso 5, imagen 2 de 3 Panasonic KX-TGA600M Keypad Replacement: paso 5, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the three screws holding the circuit-board in place.
    • The screws are located in the top right corner, bottom left corner, and bottom right corner.
  6. Panasonic KX-TGA600M Keypad Replacement: paso 6, imagen 1 de 1
    • Once the screws are out, remove the charging contacts beneath the two bottom corner screws.
  7. Panasonic KX-TGA600M Keypad Replacement: paso 7, imagen 1 de 1
    • Remove the circuit board.
  8. Panasonic KX-TGA600M Keypad Replacement: paso 8, imagen 1 de 1
    • Pull back the black silicone keypad.
Conclusión
2 personas más completaron esta guía.
Un comentario
Incomplete explanation with what materials to clean
asalmoom - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 576
