Saltar al contenido principal
Panasonic KX-TG6641 Base Display Screen Replacement
Qué necesitas
  1. Panasonic KX-TG6641 Base Display Screen Replacement, Base Display Screen: paso 1, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove five screws from the back cover.
  2. Panasonic KX-TG6641 Base Display Screen Replacement: paso 2, imagen 1 de 1
    • To remove the back cover, use an iFixit opening tool and wedge the tool in between the loosened back charging case and the front plate.
    • Wiggle to loosen, be careful to not pry too hard as it could cause damage.
  3. Panasonic KX-TG6641 Base Display Screen Replacement: paso 3, imagen 1 de 2 Panasonic KX-TG6641 Base Display Screen Replacement: paso 3, imagen 2 de 2
    • To access the display screen, use a Phillips #0 screwdriver to remove the screw on the bottom right corner of the electrical panel.
    • Unclip the wires hooked into the base.
    • It's not necessary to desolder the wires.
  4. Panasonic KX-TG6641 Base Display Screen Replacement: paso 4, imagen 1 de 1
    • Disconnect the two phone cable connectors.
    • Use a Phillips #0 to remove the screw that is fixed in the plastic holder for the connectors.
  5. Panasonic KX-TG6641 Base Display Screen Replacement: paso 5, imagen 1 de 2 Panasonic KX-TG6641 Base Display Screen Replacement: paso 5, imagen 2 de 2
    • Move the electrical panel to the side.
    • Use a Phillips #0 to remove the four screws from the brown board and lift it to access the display screen.
    • Be aware, there is a screw under the control panel, it is indicated with the central red circle.
  6. Panasonic KX-TG6641 Base Display Screen Replacement: paso 6, imagen 1 de 1
    • Remove the current display screen from the electric panel.
    • Follow this process in reverse to replace the new display screen in its place.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 409
