Saltar al contenido principal
Panasonic KX-TG6021M Back Speaker Replacement
Qué necesitas
  1. Panasonic KX-TG6021M Back Speaker Replacement, Battery: paso 1, imagen 1 de 2 Panasonic KX-TG6021M Back Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Back Speaker Replacement: paso 2, imagen 1 de 3 Panasonic KX-TG6021M Back Speaker Replacement: paso 2, imagen 2 de 3 Panasonic KX-TG6021M Back Speaker Replacement: paso 2, imagen 3 de 3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Back Speaker Replacement, Front Panel: paso 3, imagen 1 de 2 Panasonic KX-TG6021M Back Speaker Replacement, Front Panel: paso 3, imagen 2 de 2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Back Speaker Replacement: paso 4, imagen 1 de 3 Panasonic KX-TG6021M Back Speaker Replacement: paso 4, imagen 2 de 3 Panasonic KX-TG6021M Back Speaker Replacement: paso 4, imagen 3 de 3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Back Speaker Replacement: paso 5, imagen 1 de 1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Back Speaker Replacement, Back Speaker: paso 6, imagen 1 de 1
    • Twist the back speaker and pull straight out to remove it from the case.
    • To completely remove the speaker from the motherboard, you will need to desolder the speaker cables.
Conclusión
Una persona más ha completado esta guía.
Leah Meador
Miembro Desde 10/24/16
301 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-1, Baechle Fall 2016 Miembro de IUPUI, Team 3-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 605
