Saltar al contenido principal
Panasonic KX-T4000R Cordless Phone Antenna Replacement
Qué necesitas
  1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: paso 1, imagen 1 de 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: paso 1, imagen 2 de 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Panasonic KX-T4000R Cordless Phone Antenna Replacement: paso 2, imagen 1 de 3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: paso 2, imagen 2 de 3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: paso 2, imagen 3 de 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: paso 3, imagen 1 de 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: paso 3, imagen 2 de 2
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  4. Panasonic KX-T4000R Cordless Phone Antenna Replacement: paso 4, imagen 1 de 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement: paso 4, imagen 2 de 2
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
Conclusión
Elizabeth Kelly
Miembro Desde 10/22/12
501 Reputación
5 Guías creadas
Equipo
Clemson, Team 15-1, Benson Fall 2012 Miembro de Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,854
