Saltar al contenido principal
Panasonic KX-E603 Printwheel Replacement
  1. Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: paso 1, imagen 1 de 2 Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: paso 1, imagen 2 de 2
    • Open the lid of the typewriter.
  2. Panasonic KX-E603 Printwheel Replacement: paso 2, imagen 1 de 2 Panasonic KX-E603 Printwheel Replacement: paso 2, imagen 2 de 2
    • To release the green locking lever, pull it towards you.
  3. Panasonic KX-E603 Printwheel Replacement: paso 3, imagen 1 de 2 Panasonic KX-E603 Printwheel Replacement: paso 3, imagen 2 de 2
    • Gently lift to remove the old ink cartridge.
  4. Panasonic KX-E603 Printwheel Replacement, Printwheel: paso 4, imagen 1 de 2 Panasonic KX-E603 Printwheel Replacement, Printwheel: paso 4, imagen 2 de 2
    • Firmly grasp either one, or both of the plastic printwheel ends protruding from the carriage as seen.
    • Gently lift the printwheel while slightly pushing forward to remove the printwheel from its housing.
Conclusión
To reassemble your device, follow these steps in reverse using your new printwheel.
Equipo
Cal Poly, Team 17-1, Forte Spring 2015 Miembro de Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 352
