Saltar al contenido principal
Panasonic HDC-TM15 Side Cover Replacement
Qué necesitas
  1. Panasonic HDC-TM15 Side Cover Replacement, Side Cover: paso 1, imagen 1 de 1
    • Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
  2. Panasonic HDC-TM15 Side Cover Replacement: paso 2, imagen 1 de 1
    • Next, unscrew the six .5 mm Phillips #00 screws on the bottom of the camcorder.
  3. Panasonic HDC-TM15 Side Cover Replacement: paso 3, imagen 1 de 3 Panasonic HDC-TM15 Side Cover Replacement: paso 3, imagen 2 de 3 Panasonic HDC-TM15 Side Cover Replacement: paso 3, imagen 3 de 3
    • By putting your hand through the hand-strap, tug on the side cover until it comes off completely.
    • Once the old cover is completely detached, set it aside.
    • The inside of your camcorder should now be completely exposed, as seen in the photos.
  4. Panasonic HDC-TM15 Side Cover Replacement: paso 4, imagen 1 de 2 Panasonic HDC-TM15 Side Cover Replacement: paso 4, imagen 2 de 2
    • Line up the new side cover in the exact same place, ensuring that the screw holes match.
    • Re-screw the side cover into place.
  5. Panasonic HDC-TM15 Side Cover Replacement: paso 5, imagen 1 de 1
    • Gently tug on the hand-strap to ensure that the screws are tight and the side cover is secure.
    • When the side cover is securely fastened, you have completed the side cover replacement of your Panasonic HDC-TM15 camcorder.
Conclusión
Una persona más ha completado esta guía.
Tricia Fallo
Miembro Desde 03/11/15
210 Reputación
2 Guías creadas
Equipo
Marist, Team 1-4, Laflen Spring 2015 Miembro de Marist, Team 1-4, Laflen Spring 2015
MARS-LAFLEN-S15S1G4
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 326
