Introducción
The Record button can be found on the back end of the camera, beside the battery. If the record button is not functioning properly, it will need to be replaced. This guide will show a Panasonic HDC-TM15 owner how to remove the broken button and replace it with a new one.
Qué necesitas
Using the Phillips #00 Screwdriver, unscrew the five .5 mm Phillips #00 screws on the hand-strap side of the camcorder.
Casi Terminas!
Conclusión
