Saltar al contenido principal
Panasonic HC‑VX870 Hand Strap Replacement
Qué necesitas
  1. Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: paso 1, imagen 1 de 3 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: paso 1, imagen 2 de 3 Panasonic HC‑VX870 Hand Strap Replacement, Side Cover: paso 1, imagen 3 de 3
    • Unscrew the J1 screws on the left side of the camcorder.
    • Unscrew the marked screws on the bottom of the camcorder.
    • Unscrew the marked screws on the back of the camcorder.
  2. Panasonic HC‑VX870 Hand Strap Replacement: paso 2, imagen 1 de 2 Panasonic HC‑VX870 Hand Strap Replacement: paso 2, imagen 2 de 2
    • Pull off the left side of the camcorder. You may have to use a little force but don't worry about breaking anything in the camcorder.
  3. Panasonic HC‑VX870 Hand Strap Replacement, Record Button Mechanism: paso 3, imagen 1 de 1
    • Unscrew the indicated screw.
  4. Panasonic HC‑VX870 Hand Strap Replacement: paso 4, imagen 1 de 1
    • Lift up on the little tab indicated in the picture and push away from the camera in order to remove the record button.
  5. Panasonic HC‑VX870 Hand Strap Replacement: paso 5, imagen 1 de 3 Panasonic HC‑VX870 Hand Strap Replacement: paso 5, imagen 2 de 3 Panasonic HC‑VX870 Hand Strap Replacement: paso 5, imagen 3 de 3
    • Take out the piece that that was held in place by the screw and separate the smaller piece from the larger piece.
  6. Panasonic HC‑VX870 Hand Strap Replacement, Hand Strap: paso 6, imagen 1 de 1
    • Use the plastic opening tool to pry the little metal bar out of place in order to release one side of the hand strap.
  7. Panasonic HC‑VX870 Hand Strap Replacement: paso 7, imagen 1 de 1
    • Unscrew the indicated screws and remove the piece it was holding in place.
  8. Panasonic HC‑VX870 Hand Strap Replacement: paso 8, imagen 1 de 1
    • Repeat step 3 for this side of the strap.
  9. Panasonic HC‑VX870 Hand Strap Replacement: paso 9, imagen 1 de 1
    • Pull the handle straps out of their holes to remove the strap.
Conclusión
Rebecca Maloney
Miembro Desde 01/24/17
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-6, Banghart Winter 2017 Miembro de Cal Poly, Team 13-6, Banghart Winter 2017
CPSU-BANGHART-W17S13G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 595
