Saltar al contenido principal
Panasonic ER430K Battery Replacement
Qué necesitas
  1. Panasonic ER430K Battery Replacement, Battery: paso 1, imagen 1 de 2 Panasonic ER430K Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the battery cover by rotating it counter -clockwise and lifting it off.
    • Tilt the trimmer to the bottom, you will notice the battery housing.
  2. Panasonic ER430K Battery Replacement: paso 2, imagen 1 de 1
    • Insert the AA Battery according to the terminals on the Battery housing.
    • Note the '+' side in the the housing and the '-' side on the cover.
  3. Panasonic ER430K Battery Replacement: paso 3, imagen 1 de 1
    • Twist the battery cover housing in a clockwise direction to secure the the battery.
Conclusión
Dileep Balaji
Miembro Desde 09/26/15
276 Reputación
1 Guía escrita
Equipo
IUPUI, Team S22-G2, Bayer Fall 2017 Miembro de IUPUI, Team S22-G2, Bayer Fall 2017
IUPUI-BAYER-F17S22G2
4 Miembros
3 Guías creadas
2 comentarios
Battery + side goes in first (when battery is inserted correctly, the - side will be facing you).
Marc2 Salvisberg - Contestar
i prided the negative tab on the cover up to make contact. the trimmer roared to life again!
Dean Jarvis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 54
Todo El Tiempo: 4,572
