Introducción
Is your blade not spinning when you turn on your device, even when you hear the motor run? Check out this guide to replace your motor shaft.
Qué necesitas
Casi Terminas!
Conclusión
2 comentarios
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
