Saltar al contenido principal
Panasonic ER-GN30-K Motor Replacement
Qué necesitas
  1. Panasonic ER-GN30-K Motor Replacement, Motor: paso 1, imagen 1 de 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: paso 2, imagen 1 de 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: paso 3, imagen 1 de 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: paso 4, imagen 1 de 1
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: paso 5, imagen 1 de 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: paso 6, imagen 1 de 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: paso 7, imagen 1 de 2 Panasonic ER-GN30-K Motor Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: paso 8, imagen 1 de 1
    • Remove the motor from the case by sliding the cover off of it.
Conclusión
6 personas más completaron esta guía.
Corey Tappan
Miembro Desde 08/27/15
209 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 15-3, Blackwell Fall 2015 Miembro de USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Miembros
5 Guías creadas
Un comentario
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 39
Todo El Tiempo: 3,561
