Qué necesitas
Flip cellphone open.
Out of the iFixit tool kit remove the black plastic opening tool, curved tweezers, and 54 bit driver kit.
Insert nylon spudger or curved tweezers into small gap between the phone's outer gray casing and the inner gray plastic compartment (which holds the green circuit board and screen together). This gap is indicated by red arrows.
Use the tools as leverage to pop out inner gray compartment unit (screen, gray plastic, and circuit board) away from the phones outer casing .
At rectangular holes on the sides of screen, use tweezers to remove the screen from the gray plastic component by slipping tweezers under the white tray holding the screen.
