Saltar al contenido principal
Panasonic DVD-RV31 Player Left Control Board Replacement
Qué necesitas
  1. Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: paso 1, imagen 1 de 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: paso 1, imagen 2 de 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Panasonic DVD-RV31 Player Left Control Board Replacement: paso 2, imagen 1 de 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: paso 3, imagen 1 de 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: paso 3, imagen 2 de 2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  4. Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: paso 4, imagen 1 de 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: paso 4, imagen 2 de 2
    • Grip jogger dial and lift up. It should come off easily.
  5. Panasonic DVD-RV31 Player Left Control Board Replacement: paso 5, imagen 1 de 3 Panasonic DVD-RV31 Player Left Control Board Replacement: paso 5, imagen 2 de 3 Panasonic DVD-RV31 Player Left Control Board Replacement: paso 5, imagen 3 de 3
    • Remove 4 mounting screws as shown.
    • Unscrew and save brass tab.
    • Push in 2 plastic retainers and lift out.
Conclusión
Kevin
Miembro Desde 04/26/11
375 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 18-20, Garner Spring 2011 Miembro de Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 2,172
