Saltar al contenido principal
Panasonic DMC-FZ70 Viewfinder Replacement
Qué necesitas
  1. Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: paso 1, imagen 1 de 2 Panasonic DMC-FZ70 Viewfinder Replacement, Back Panel: paso 1, imagen 2 de 2
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Viewfinder Replacement: paso 2, imagen 1 de 2 Panasonic DMC-FZ70 Viewfinder Replacement: paso 2, imagen 2 de 2
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Viewfinder Replacement: paso 3, imagen 1 de 2 Panasonic DMC-FZ70 Viewfinder Replacement: paso 3, imagen 2 de 2
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Viewfinder Replacement: paso 4, imagen 1 de 2 Panasonic DMC-FZ70 Viewfinder Replacement: paso 4, imagen 2 de 2
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Viewfinder Replacement: paso 5, imagen 1 de 1
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Viewfinder Replacement: paso 6, imagen 1 de 1
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Viewfinder Replacement: paso 7, imagen 1 de 3 Panasonic DMC-FZ70 Viewfinder Replacement: paso 7, imagen 2 de 3 Panasonic DMC-FZ70 Viewfinder Replacement: paso 7, imagen 3 de 3
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: paso 8, imagen 1 de 2 Panasonic DMC-FZ70 Viewfinder Replacement, Viewfinder: paso 8, imagen 2 de 2
    • Using a plastic opening tool, flip up the black switch on the ZIF connector that attaches the viewfinder to the motherboard.
    • Once the connector has been opened, gently pull the cable from its slot.
  9. Panasonic DMC-FZ70 Viewfinder Replacement: paso 9, imagen 1 de 2 Panasonic DMC-FZ70 Viewfinder Replacement: paso 9, imagen 2 de 2
    • Holding the sides of the viewfinder, pull it out of the camera.
    • Removing the viewfinder requires a strong, yet steady pull.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 21-3, Maness Winter 2017 Miembro de Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Miembros
12 Guías creadas
Un comentario
Wow, this is very HELPFUL! I saved it with Zotero in case I need it one day. I'm simply looking for an eyepiece extender and/or rubber eyepiece combo. If you have a good source Photo Supply you'd recommend, please do so.
Mr. Phil - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 26
Todo El Tiempo: 1,200
