Saltar al contenido principal
Panasonic DMC-FZ70 Operation Unit Replacement
Qué necesitas
  1. Panasonic DMC-FZ70 Operation  Unit Replacement, Back Panel: paso 1, imagen 1 de 2 Panasonic DMC-FZ70 Operation  Unit Replacement, Back Panel: paso 1, imagen 2 de 2
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 2, imagen 1 de 2 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 2, imagen 2 de 2
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 3, imagen 1 de 2 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 3, imagen 2 de 2
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 4, imagen 1 de 2 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 4, imagen 2 de 2
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 5, imagen 1 de 1
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 6, imagen 1 de 1
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 7, imagen 1 de 3 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 7, imagen 2 de 3 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 7, imagen 3 de 3
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Operation  Unit Replacement, Motherboard: paso 8, imagen 1 de 1
    • Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
  9. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 9, imagen 1 de 3 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 9, imagen 2 de 3 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 9, imagen 3 de 3
    • The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting the black strip on the rectangular connection socket.
    • Carefully pull each of the ribbon cables out of their sockets.
    • The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
  10. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 10, imagen 1 de 2 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 10, imagen 2 de 2
    • Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
  11. Panasonic DMC-FZ70 Operation  Unit Replacement, Operation  Unit: paso 11, imagen 1 de 2 Panasonic DMC-FZ70 Operation  Unit Replacement, Operation  Unit: paso 11, imagen 2 de 2
    • Unscrew one 10mm Phillips screw to the right and underneath the viewfinder.
  12. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 12, imagen 1 de 1
    • Using a plastic opening tool, flip up the switch on the ZIF connector underneath the operations unit and pull the ribbon out of the motherboard.
  13. Panasonic DMC-FZ70 Operation  Unit Replacement: paso 13, imagen 1 de 3 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 13, imagen 2 de 3 Panasonic DMC-FZ70 Operation  Unit Replacement: paso 13, imagen 3 de 3
    • Slide out and replace the operation unit.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team 21-3, Maness Winter 2017 Miembro de Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Miembros
12 Guías creadas
Un comentario
Alberto,
Great instructions! Saved me $165 (compared to camera repair shop).
Professor Roy Hinkley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 44
Todo El Tiempo: 2,090
