Saltar al contenido principal
Panasonic DECT 6.0 Button Replacement
Qué necesitas
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: paso 1, imagen 1 de 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: paso 1, imagen 2 de 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: paso 1, imagen 3 de 3
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
  2. Panasonic DECT  6.0 Button Replacement: paso 2, imagen 1 de 3 Panasonic DECT  6.0 Button Replacement: paso 2, imagen 2 de 3 Panasonic DECT  6.0 Button Replacement: paso 2, imagen 3 de 3
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
  3. Panasonic DECT  6.0 Button Replacement: paso 3, imagen 1 de 3 Panasonic DECT  6.0 Button Replacement: paso 3, imagen 2 de 3 Panasonic DECT  6.0 Button Replacement: paso 3, imagen 3 de 3
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
  4. Panasonic DECT  6.0 Button Replacement: paso 4, imagen 1 de 3 Panasonic DECT  6.0 Button Replacement: paso 4, imagen 2 de 3 Panasonic DECT  6.0 Button Replacement: paso 4, imagen 3 de 3
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
  5. Panasonic DECT  6.0 Button Replacement: paso 5, imagen 1 de 2 Panasonic DECT  6.0 Button Replacement: paso 5, imagen 2 de 2
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
Conclusión
Una persona más ha completado esta guía.
Jacob
Miembro Desde 05/31/16
131 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 536
