Saltar al contenido principal
Panasonic Camera DMC FX37 Battery Door Replacement
Qué necesitas
  1. Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: paso 1, imagen 1 de 2 Panasonic Camera DMC FX37 Battery Door Replacement, Battery Door: paso 1, imagen 2 de 2
    • Set the switch on the battery door to "open," and open the door.
  2. Panasonic Camera DMC FX37 Battery Door Replacement: paso 2, imagen 1 de 1
    • At the left hand side, locate the head of the metal bar that holds the spring in place.
  3. Panasonic Camera DMC FX37 Battery Door Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Push the metal bar down using the metal tweezers.
  4. Panasonic Camera DMC FX37 Battery Door Replacement: paso 4, imagen 1 de 1
    • Pull the metal bar that holds the spring in place out.
    • You can also use tweezers for this step, although we found it easier to just use our fingers.
  5. Panasonic Camera DMC FX37 Battery Door Replacement: paso 5, imagen 1 de 1
    • Remove the battery access door from the device.
    • In order to keep the "springiness" of the door, be sure that the long arm of the spring is not over the hole for the battery.
Conclusión
Zhentao
Miembro Desde 01/30/18
247 Reputación
2 Guías creadas
Equipo
Baylor, Team S2-G3, Johnson Spring 2018 Miembro de Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 266
