Saltar al contenido principal
Panasonic CF-31 Toughbook Keyboard Replacement
Qué necesitas
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: paso 1, imagen 1 de 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: paso 1, imagen 2 de 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: paso 1, imagen 3 de 3
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 2, imagen 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 3, imagen 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 3, imagen 2 de 2
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 4, imagen 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 4, imagen 2 de 2
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 5, imagen 1 de 1
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 6, imagen 1 de 1
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 7, imagen 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: paso 7, imagen 2 de 2
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
Conclusión
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
Miembro Desde 01/16/19
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 53
Todo El Tiempo: 2,350
