Saltar al contenido principal
Panasonic ARC ES-LT3N Battery Replacement
Qué necesitas
  1. Panasonic ARC ES-LT3N Battery Replacement, Back Casing: paso 1, imagen 1 de 2 Panasonic ARC ES-LT3N Battery Replacement, Back Casing: paso 1, imagen 2 de 2
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Battery Replacement: paso 2, imagen 1 de 2 Panasonic ARC ES-LT3N Battery Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Battery Replacement: paso 3, imagen 1 de 2 Panasonic ARC ES-LT3N Battery Replacement: paso 3, imagen 2 de 2
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Battery Replacement: paso 4, imagen 1 de 2 Panasonic ARC ES-LT3N Battery Replacement: paso 4, imagen 2 de 2
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
  5. Panasonic ARC ES-LT3N Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
  6. Panasonic ARC ES-LT3N Battery Replacement: paso 6, imagen 1 de 1
    • Remove battery case.
  7. Panasonic ARC ES-LT3N Battery Replacement: paso 7, imagen 1 de 2 Panasonic ARC ES-LT3N Battery Replacement: paso 7, imagen 2 de 2
    • Remove old battery by lifting the battery up and left.
    • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
Conclusión
2 personas más completaron esta guía.
Andrew Trainor
Miembro Desde 03/05/17
603 Reputación
5 Guías creadas
Equipo
Un comentario
Where does one actually find the replacement batteries though?
WooKstah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 1,701
