Saltar al contenido principal
Palm v Outer Case Replacement
Qué necesitas
  1. Palm v Outer Case Replacement, Outer Case: paso 1, imagen 1 de 1
    • Lay device face down on surface.
  2. Palm v Outer Case Replacement: paso 2, imagen 1 de 2 Palm v Outer Case Replacement: paso 2, imagen 2 de 2
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Outer Case Replacement: paso 3, imagen 1 de 1
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Outer Case Replacement: paso 4, imagen 1 de 1
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Outer Case Replacement: paso 5, imagen 1 de 3 Palm v Outer Case Replacement: paso 5, imagen 2 de 3 Palm v Outer Case Replacement: paso 5, imagen 3 de 3
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
Linea de Meta
Anthony Platt
Miembro Desde 02/09/10
66 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-25, Maness Winter 2010 Miembro de Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
4 Miembros
4 Guías creadas
Un comentario
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,589
