Saltar al contenido principal
Palm m105 Motherboard Replacement
Qué necesitas
  1. Palm m105 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Start with your intact Palm m105.
  2. Palm m105 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove protective flap by pulling directly out from the top.
    • The two clips will pop out
  3. Palm m105 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
    • The Faceplate will then easily lift off
  4. Palm m105 Motherboard Replacement: paso 4, imagen 1 de 2 Palm m105 Motherboard Replacement: paso 4, imagen 2 de 2
    • Using a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise.
    • The link to purchase this screwdriver is Located here.
  5. Palm m105 Motherboard Replacement: paso 5, imagen 1 de 1
    • This is what the device looks like once you have taken the screws out and opened the device.
  6. Palm m105 Motherboard Replacement: paso 6, imagen 1 de 1
    • The Motherboard and screen will pop out of the back case easily.
    • Be careful when doing this step, the components are fragile.
  7. Palm m105 Motherboard Replacement: paso 7, imagen 1 de 1
    • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
    • ** This step needs to be done with special care because it is very fragile.**
    • Once they are all three popped up the motherboard and screen will separate easily.
  8. Palm m105 Motherboard Replacement: paso 8, imagen 1 de 1
Conclusión
Aaron
Miembro Desde 10/04/11
7 Reputación
1 Guía escrita
Equipo
UW Stout, Team 1-3, Zhou Fall 2011 Miembro de UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,059
