Introducción
If the front and/or rear cover is cracked, this guide will teach the user to remove the damaged cover and replace with a new one.
Partes
No se requieren partes.
  1. Remove the batteries.
    • Remove the batteries.
  2. Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
    • Set aside broken cover, and replace with a new cover.
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Conclusión
Anne Carey
Miembro Desde 25/10/11
1 Reputación
3 Guías creadas
Equipo
James Madison, Team 1-3, Allen Fall 2011 Miembro de James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Miembros
5 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 469
