Saltar al contenido principal
Palm Zire m150 Battery Replacement
Qué necesitas
  1. Palm Zire m150 Battery Replacement, Battery: paso 1, imagen 1 de 2 Palm Zire m150 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • To begin, gently pull on the flap to remove.
  2. Palm Zire m150 Battery Replacement: paso 2, imagen 1 de 1
    • Use T6 bit of screwdriver provided in the iFixit toolkit. Unscrew the two screws at the top of the device.
  3. Palm Zire m150 Battery Replacement: paso 3, imagen 1 de 2 Palm Zire m150 Battery Replacement: paso 3, imagen 2 de 2
    • Carefully remove the back panel of the device.
  4. Palm Zire m150 Battery Replacement: paso 4, imagen 1 de 2 Palm Zire m150 Battery Replacement: paso 4, imagen 2 de 2
    • Gently remove the battery from the phone.
  5. Palm Zire m150 Battery Replacement: paso 5, imagen 1 de 1
    • Insert new battery where old battery was.
    • To reassemble your device, follow these steps in reverse order
Conclusión
Kate
Miembro Desde 01/26/16
528 Reputación
5 Guías creadas
Un comentario
Why is nothing said about soldering of battery terminals, which I read elsewhere as a requirement?
Carlton Barnett - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 1,431
