Introducción
Use this guide to replace a screen that is cracked or otherwise broken. Ensure that the problem can't be eliminated any other way, such as with a reset. See the Zire72v1 Troubleshooting page for other techniques to use on a faulty device.
Qué necesitas
Having successfully completed the Palm Zire72v1 Teardown, your device should now closely resemble this picture.
The front and back panels should be separated and laid side-by-side.
The front panel is on the left and contains the screen and navigation buttons.
The back panel is on the right and contains the circuit board and battery.
Una persona más ha completado esta guía.
Un comentario
A very clear process description, thank you very much.
And the disassembly process described works for battery replacement too.
But where can I find a replacement screen? One that doesn't cost the earth? And where too can I find a battery replacement?
TIA,
JC in Canberra, Australia
jthadcarroll@yahoo.com.au
