Saltar al contenido principal
Palm Zire 72v1 Screen Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Palm Zire 72v1 Screen Replacement, Zire 72v1: paso 1, imagen 1 de 1
    • Power off your Zire 72 and turn the unit over.
    • Remove the two screws on the bottom of the rear of the unit.
    • Peel back the information sticker.
    • Remove the one screw that connects the metal panel to the body of the Zire72.
    • Use the tip of your screwdriver to pop the metal panel off the top of the rear of the unit to expose two more screws on the top corners.
  2. Palm Zire 72v1 Screen Replacement: paso 5, imagen 1 de 2 Palm Zire 72v1 Screen Replacement: paso 5, imagen 2 de 2
    • Remove the two top screws.
    • Insert the tip of your screwdriver in the seam where the front frame meets the body of the unit and pry the frame up to pop it off. Remove it.
  3. Palm Zire 72v1 Screen Replacement: paso 7, imagen 1 de 1
    • Pull the back panel off the body of the unit to expose the motherboard in the body.
    • Unplug the two orange ribbon cables at the top of the motherboard and remove the motherboard from the body. All that is left is the LCD screen in the front housing of the unit.
  4. Palm Zire 72v1 Screen Replacement: paso 9, imagen 1 de 1
    • Remove the screen from the front housing and set it aside.
    • Now that you have your Zire open, you can remove and replace the defective part.
  5. Palm Zire 72v1 Screen Replacement, Screen: paso 11, imagen 1 de 1
    • Having successfully completed the Palm Zire72v1 Teardown, your device should now closely resemble this picture.
    • The front and back panels should be separated and laid side-by-side.
    • The front panel is on the left and contains the screen and navigation buttons.
    • The back panel is on the right and contains the circuit board and battery.
  6. Palm Zire 72v1 Screen Replacement: paso 12, imagen 1 de 1
    • To replace the screen, you will be working exclusively with the front (left) panel.
  7. Palm Zire 72v1 Screen Replacement: paso 13, imagen 1 de 1
    • Remove the old screen by sliding it upward and out of the plastic shell.
    • The navigation panel may be removed if it interferes with screen replacement.
  8. Palm Zire 72v1 Screen Replacement: paso 14, imagen 1 de 1
    • Once the old screen is completely, you be left with the plastic shell.
    • The new screen will be inserted into this case.
  9. Palm Zire 72v1 Screen Replacement: paso 15, imagen 1 de 1
    • The old screen will be entirely separate from the rest of the device.
    • Dispose of this broken technology responsibly.
    • You are now set to insert the new screen and reassemble the device.
Conclusión
Una persona más ha completado esta guía.
Cherri
Miembro Desde 09/08/11
37 Reputación
1 Guía escrita
Un comentario
A very clear process description, thank you very much.
And the disassembly process described works for battery replacement too.
But where can I find a replacement screen? One that doesn't cost the earth? And where too can I find a battery replacement?
TIA,
JC in Canberra, Australia
jthadcarroll@yahoo.com.au
jthadcarroll - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,297
