Saltar al contenido principal
Palm Zire 71 Battery Replacement
Qué necesitas
  1. Palm Zire 71 Battery Replacement, Preparation: paso 1, imagen 1 de 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Battery Replacement, Top Screws (2) Removal: paso 2, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Battery Replacement, Bottom Screws (3) Removal: paso 3, imagen 1 de 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Battery Replacement, Front Panel Removal: paso 4, imagen 1 de 2 Palm Zire 71 Battery Replacement, Front Panel Removal: paso 4, imagen 2 de 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: paso 5, imagen 1 de 2 Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: paso 5, imagen 2 de 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Battery Replacement, Back Cover: paso 6, imagen 1 de 2 Palm Zire 71 Battery Replacement, Back Cover: paso 6, imagen 2 de 2
    • Slide the back cover off.
  7. Palm Zire 71 Battery Replacement, Battery: paso 7, imagen 1 de 1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Battery Replacement: paso 8, imagen 1 de 2 Palm Zire 71 Battery Replacement: paso 8, imagen 2 de 2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Battery Replacement: paso 9, imagen 1 de 3 Palm Zire 71 Battery Replacement: paso 9, imagen 2 de 3 Palm Zire 71 Battery Replacement: paso 9, imagen 3 de 3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Battery Replacement: paso 10, imagen 1 de 3 Palm Zire 71 Battery Replacement: paso 10, imagen 2 de 3 Palm Zire 71 Battery Replacement: paso 10, imagen 3 de 3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
Conclusión
7 personas más completaron esta guía.
Jinxian Jiang
Miembro Desde 04/28/11
245 Reputación
3 Guías creadas
Equipo
Un comentario
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 39
Todo El Tiempo: 9,149
