Saltar al contenido principal
Palm Zire 71 Back Cover Replacement
Qué necesitas
  1. Palm Zire 71 Back Cover Replacement, Preparation: paso 1, imagen 1 de 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Back Cover Replacement, Top Screws (2) Removal: paso 2, imagen 1 de 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Back Cover Replacement, Bottom Screws (3) Removal: paso 3, imagen 1 de 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Back Cover Replacement, Front Panel Removal: paso 4, imagen 1 de 2 Palm Zire 71 Back Cover Replacement, Front Panel Removal: paso 4, imagen 2 de 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: paso 5, imagen 1 de 2 Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: paso 5, imagen 2 de 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Back Cover Replacement, Back Cover: paso 6, imagen 1 de 2 Palm Zire 71 Back Cover Replacement, Back Cover: paso 6, imagen 2 de 2
    • Slide the back cover off.
Conclusión
Una persona más ha completado esta guía.
Jinxian Jiang
Miembro Desde 04/28/11
245 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 2,461
