Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If you know that your screen needs to be replaced, this guide will show you how to do so.
  1. Unscrew the two 7.35mm Torx T6 screws.
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  4. Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  5. Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  6. Carefully pull back the brown cable holders and separate the screen from the motherboard.
    • Carefully pull back the brown cable holders and separate the screen from the motherboard.
Conclusión
Gabe
Miembro Desde 23/01/11
501 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 5-21, Amido Winter 2011 Miembro de Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 2,273
