1. Unscrew the two 7.35mm Torx T6 screws.
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  5. Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard.  The front blue panel should fall right off.
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
Conclusión
Antonio
Miembro Desde 23/01/11
101 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 5-21, Amido Winter 2011 Miembro de Cal Poly, Team 5-21, Amido Winter 2011
CPSU-AMIDO-W11S5G21
4 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,221
