Saltar al contenido principal
Palm Zire 21 Battery Replacement
Qué necesitas
  1. Palm Zire 21 Battery Replacement, Battery: paso 1, imagen 1 de 2 Palm Zire 21 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the two 0.8mm screws located on the back of the device.
  2. Palm Zire 21 Battery Replacement: paso 2, imagen 1 de 3 Palm Zire 21 Battery Replacement: paso 2, imagen 2 de 3 Palm Zire 21 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the back cover from the device exposing the battery.
  3. Palm Zire 21 Battery Replacement: paso 3, imagen 1 de 1
    • Using a plastic opening tool, small flathead screwdriver, or small knife blade pry the battery away from the motherboard. Be careful not to pry to fast, or you could rip the wires off during this stage.
  4. Palm Zire 21 Battery Replacement: paso 4, imagen 1 de 1
    • Carefully remove the battery from the motherboard.
  5. Palm Zire 21 Battery Replacement: paso 5, imagen 1 de 1
    • Unwrap the old battery from electrical tape and replace with new battery.
Conclusión
Jeremy Craft
Miembro Desde 09/26/14
301 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,408
