Saltar al contenido principal
Palm Treo Pro Display Glass Replacement
Qué necesitas
  1. Palm Treo Pro Display Glass Replacement, Battery: paso 1, imagen 1 de 3 Palm Treo Pro Display Glass Replacement, Battery: paso 1, imagen 2 de 3 Palm Treo Pro Display Glass Replacement, Battery: paso 1, imagen 3 de 3
    • Press down on the back of the case and slide forward to remove it.
  2. Palm Treo Pro Display Glass Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling up on the tab near the camera lens.
    • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
  3. Palm Treo Pro Display Glass Replacement, Motherboard: paso 3, imagen 1 de 3 Palm Treo Pro Display Glass Replacement, Motherboard: paso 3, imagen 2 de 3 Palm Treo Pro Display Glass Replacement, Motherboard: paso 3, imagen 3 de 3
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
  4. Palm Treo Pro Display Glass Replacement: paso 4, imagen 1 de 3 Palm Treo Pro Display Glass Replacement: paso 4, imagen 2 de 3 Palm Treo Pro Display Glass Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
  5. Palm Treo Pro Display Glass Replacement: paso 5, imagen 1 de 3 Palm Treo Pro Display Glass Replacement: paso 5, imagen 2 de 3 Palm Treo Pro Display Glass Replacement: paso 5, imagen 3 de 3
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
  6. Palm Treo Pro Display Glass Replacement: paso 6, imagen 1 de 3 Palm Treo Pro Display Glass Replacement: paso 6, imagen 2 de 3 Palm Treo Pro Display Glass Replacement: paso 6, imagen 3 de 3
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
  7. Palm Treo Pro Display Glass Replacement: paso 7, imagen 1 de 2 Palm Treo Pro Display Glass Replacement: paso 7, imagen 2 de 2
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
  8. Palm Treo Pro Display Glass Replacement: paso 8, imagen 1 de 3 Palm Treo Pro Display Glass Replacement: paso 8, imagen 2 de 3 Palm Treo Pro Display Glass Replacement: paso 8, imagen 3 de 3
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
  9. Palm Treo Pro Display Glass Replacement: paso 9, imagen 1 de 3 Palm Treo Pro Display Glass Replacement: paso 9, imagen 2 de 3 Palm Treo Pro Display Glass Replacement: paso 9, imagen 3 de 3
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
  10. Palm Treo Pro Display Glass Replacement, Display Glass: paso 10, imagen 1 de 2 Palm Treo Pro Display Glass Replacement, Display Glass: paso 10, imagen 2 de 2
    • Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
    • Note: The display glass is the metallic rectangle with a orange ribbon cable attached to it.
Conclusión
Una persona más ha completado esta guía.
Kyle Gilbert
Miembro Desde 04/17/13
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 8-59, Johann Spring 2013 Miembro de Cal Poly, Team 8-59, Johann Spring 2013
CPSU-JOHANN-S13S8G59
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 304
