Introducción
Remove the screen for replacement or cleaning.
Herramientas
Partes
No se especificaron partes.
Press the button on the back cover to release the battery cover.
Slide off the battery cover.
Remove the stylus by pulling up on the large top to reveal the top left case screw.
Pull away the black flap to reveal the top right case screw.
Use the T5 screwdriver attachment to remove the 5 black back case screws marked by the red and yellow circles. These screws are 0.274 inches long.
Use the same T5 screwdriver attachment to remove the middle screw marked by the blue circle. It is shorter than the other screws at 0.121 inches in length.
Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
Gently peel off the protective yellow tape covering the ribbon cable using tweezers or your fingers.
Using your fingers gently lift the display screen panel out of the casing by either grasping it from the back or popping it out of the front.
