Introducción
One the back cover has been removed from the phone, 4 black clips will be popped off to reveal the antenna. Then it pops off.
Partes
No se requieren partes.
Press the button on the back cover to release the battery cover. Slide off the battery cover. Slide off the battery cover.
  • Press the button on the back cover to release the battery cover.
  • Slide off the battery cover.
Agregar Comentario
Remove the battery by lifting up on one side. Remove the battery by lifting up on one side.
  • Remove the battery by lifting up on one side.
Agregar Comentario
Remove the stylus by pulling up on the large top to reveal the top left case screw. Pull away the black flap to reveal the top right case screw.
  • Remove the stylus by pulling up on the large top to reveal the top left case screw.
  • Pull away the black flap to reveal the top right case screw.
Agregar Comentario
WARNING: The top right red screw marked by the red circle has a warranty seal. Removing this seal will void your warranty.
  • WARNING: The top right red screw marked by the red circle has a warranty seal. Removing this seal will void your warranty.
  • Use the T5 screwdriver attachment to remove the 5 black back case screws marked by the red and yellow circles. These screws are 0.274 inches long.
  • Use the same T5 screwdriver attachment to remove the middle screw marked by the blue circle. It is shorter than the other screws at 0.121 inches in length.
Agregar Comentario
Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top. ATTENTION: Side volume control buttons may fall out after opening the device.
  • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
  • ATTENTION: Side volume control buttons may fall out after opening the device.
Agregar Comentario
Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the yellow box. WARNING: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the yellow box.
  • WARNING: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
Agregar Comentario
Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves. Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves. Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
Agregar Comentario
The antenna is on the back half of the phone, and is marked by the yellow square.
  • The antenna is on the back half of the phone, and is marked by the yellow square.
Agregar Comentario
Press in the four black clips using the 025 Flathead screwdriver attachment to pop off the upper--back cover. Press in the four black clips using the 025 Flathead screwdriver attachment to pop off the upper--back cover.
  • Press in the four black clips using the 025 Flathead screwdriver attachment to pop off the upper--back cover.
Agregar Comentario
Lift off the top of the back cover from the phone frame after undoing the clips.
  • Lift off the top of the back cover from the phone frame after undoing the clips.
Agregar Comentario
Gently pop off the antenna by pulling it away from the back cover. Gently pop off the antenna by pulling it away from the back cover.
  • Gently pop off the antenna by pulling it away from the back cover.
Agregar Comentario
Conclusión
Mike Shaw
Miembro Desde 03/01/11
601 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 14-6, Forte Winter 2011 Miembro de Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,593
