Saltar al contenido principal
Introducción
Follow this guide to gain access to your Treo's motherboard.
  1. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Use the small notch on the left hand side of the phone to remove the battery. Use the small notch on the left hand side of the phone to remove the battery.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Remove the stylus from the phone.
    • Remove the stylus from the phone.
  4. After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Using the spudger, remove the small rubberized patch under the antenna.
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Unscrew the last two screws using the previous screw driver.
    • Unscrew the last two screws using the previous screw driver.
  7. Using the plastic opening tool, gently separate the back case from the phone body. Using the plastic opening tool, gently separate the back case from the phone body.
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3). Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3). Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1). Once unscrewed, gently detach the antenna chip with your hands (Picture 2). Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1). Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2). Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3). Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
Conclusión
Ivan
Miembro Desde 29/04/12
11 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 12-37, Regan Spring 2012 Miembro de Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 704
