Saltar al contenido principal
Palm Treo 680 Microphone Replacement
Qué necesitas
  1. Palm Treo 680 Microphone Replacement, Battery: paso 1, imagen 1 de 2 Palm Treo 680 Microphone Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Microphone Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Microphone Replacement, Back Panel: paso 3, imagen 1 de 2 Palm Treo 680 Microphone Replacement, Back Panel: paso 3, imagen 2 de 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Microphone Replacement: paso 4, imagen 1 de 2 Palm Treo 680 Microphone Replacement: paso 4, imagen 2 de 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Microphone Replacement: paso 5, imagen 1 de 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Microphone Replacement: paso 6, imagen 1 de 3 Palm Treo 680 Microphone Replacement: paso 6, imagen 2 de 3 Palm Treo 680 Microphone Replacement: paso 6, imagen 3 de 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 Microphone Replacement, Microphone: paso 7, imagen 1 de 2 Palm Treo 680 Microphone Replacement, Microphone: paso 7, imagen 2 de 2
    • Using a pair of tweezers, grasp the blue rubber microphone.
    • Pull the rubber microphone up and back to remove it.
    • Now you have successfully removed the microphone.
Conclusión
2 personas más completaron esta guía.
Maiya123
Miembro Desde 10/22/09
51 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-4, Maness Fall 2009 Miembro de Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 4,133
