Saltar al contenido principal
Palm Treo 650 Motherboard Replacement
Qué necesitas
  1. Palm Treo 650 Motherboard Replacement, Battery and Stylus: paso 1, imagen 1 de 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Motherboard Replacement: paso 2, imagen 1 de 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Motherboard Replacement: paso 3, imagen 1 de 2 Palm Treo 650 Motherboard Replacement: paso 3, imagen 2 de 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Motherboard Replacement, Case: paso 4, imagen 1 de 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Motherboard Replacement: paso 5, imagen 1 de 2 Palm Treo 650 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Motherboard Replacement: paso 6, imagen 1 de 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Motherboard Replacement: paso 7, imagen 1 de 2 Palm Treo 650 Motherboard Replacement: paso 7, imagen 2 de 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 3 Palm Treo 650 Motherboard Replacement, Motherboard: paso 8, imagen 2 de 3 Palm Treo 650 Motherboard Replacement, Motherboard: paso 8, imagen 3 de 3
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 Motherboard Replacement: paso 9, imagen 1 de 2 Palm Treo 650 Motherboard Replacement: paso 9, imagen 2 de 2
    • Pull off the motherboard.
Conclusión
2 personas más completaron esta guía.
mmedrano
Miembro Desde 11/15/09
95 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 19-3, Maness Fall 2009 Miembro de Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 4,279
