Saltar al contenido principal
Palm Treo 600 Screen Replacement
Qué necesitas
  1. Palm Treo 600 Screen Replacement, Back Case: paso 1, imagen 1 de 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Screen Replacement: paso 2, imagen 1 de 2 Palm Treo 600 Screen Replacement: paso 2, imagen 2 de 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Screen Replacement: paso 3, imagen 1 de 2 Palm Treo 600 Screen Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Screen Replacement, Front Case: paso 4, imagen 1 de 2 Palm Treo 600 Screen Replacement, Front Case: paso 4, imagen 2 de 2
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Palm Treo 600 Screen Replacement, Screen: paso 5, imagen 1 de 1
    • The screen is connected to the phone with an orange data cable.
    • Slide the spudger as close to the connection as possible.
    • Gently pull the spudger up and the cable should come out of the socket.
  6. Palm Treo 600 Screen Replacement: paso 6, imagen 1 de 2 Palm Treo 600 Screen Replacement: paso 6, imagen 2 de 2
    • Once the cable is unplugged, you can remove the screen from the body.
Conclusión
Equipo
Cal Poly, Team 13-23, Maness Winter 2010 Miembro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 2,185
