Saltar al contenido principal
Palm Treo 600 Logic Board Replacement
Qué necesitas
  1. Palm Treo 600 Logic Board Replacement, Back Case: paso 1, imagen 1 de 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Logic Board Replacement: paso 2, imagen 1 de 2 Palm Treo 600 Logic Board Replacement: paso 2, imagen 2 de 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Logic Board Replacement: paso 3, imagen 1 de 2 Palm Treo 600 Logic Board Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Logic Board Replacement, Motherboard: paso 4, imagen 1 de 1
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  5. Palm Treo 600 Logic Board Replacement: paso 5, imagen 1 de 1
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  6. Palm Treo 600 Logic Board Replacement: paso 6, imagen 1 de 1
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  7. Palm Treo 600 Logic Board Replacement: paso 7, imagen 1 de 2 Palm Treo 600 Logic Board Replacement: paso 7, imagen 2 de 2
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
Conclusión
Equipo
Cal Poly, Team 13-23, Maness Winter 2010 Miembro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 11
Todo El Tiempo: 1,512
