Saltar al contenido principal
Palm Treo 600 Battery Replacement
Qué necesitas
  1. Palm Treo 600 Battery Replacement, Back Case: paso 1, imagen 1 de 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Battery Replacement: paso 2, imagen 1 de 2 Palm Treo 600 Battery Replacement: paso 2, imagen 2 de 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Battery Replacement: paso 3, imagen 1 de 2 Palm Treo 600 Battery Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Battery Replacement, Battery: paso 4, imagen 1 de 2 Palm Treo 600 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Using metal tweezers, unplug small white plug.
    • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
  5. Palm Treo 600 Battery Replacement: paso 5, imagen 1 de 1
    • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
    • The battery may be glued to the phone.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 13-23, Maness Winter 2010 Miembro de Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 12
Todo El Tiempo: 5,538
