Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Removing the back panel allows you to access the various parts of the Palm T|X PDA.
Partes
No se especificaron partes.
  1. Orient the device so that the display faces forward. Remove the stylus from the right side.
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Turn over the device so that the back panel faces forward.
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Essential Electronics Toolkit
    Pequeño juego de herramientas. Grandes posibilidades.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Rotate the device so that the display faces forward. Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  5. Carefully pry the back panel to open the device. Be careful not to break the wire that connects the battery pack to the motherboard.
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  6. Use a plastic opening tool to peel the battery pack from the back panel. The battery pack is glued to the back panel so removing it may require considerable effort.
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
Conclusión
Una persona más ha completado esta guía.
Spencer Lewson
Miembro Desde 19/01/11
748 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 1-15, Amido Winter 2011 Miembro de Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,264
