Partes
No se requieren partes.
  1. Make sure your Palm Pre is turned off before disassembling the phone.
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Carefully pull up on the tab to remove the current battery.
    • Carefully pull up on the tab to remove the current battery.
    • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
    • Use the spudger to locate the crease at the bottom of the keyboard.
    • Carefully work your way around the phone separating the back frame from the keyboard.
    • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
    • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
      • Make sure to take note of the orientation of the speaker for re-installation.
      • Make sure not the puncture the screen on the outside of the back frame.
Conclusión
noha
Miembro Desde 12/04/12
139 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 7-31, Maness Spring 2012 Miembro de Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Miembros
16 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,065
