Saltar al contenido principal
Palm Pre Speaker Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Palm Pre Speaker Replacement, Antenna: paso 1, imagen 1 de 2 Palm Pre Speaker Replacement, Antenna: paso 1, imagen 2 de 2
    • First the back panel must be removed to reveal the battery.
    • Remove the battery pack.
  2. Palm Pre Speaker Replacement: paso 2, imagen 1 de 2 Palm Pre Speaker Replacement: paso 2, imagen 2 de 2
    • Remove the six T5 screws necessary to separate the backplate from the phone.
    • There is one screw in the upper right that is concealed by a small sticker labeled "Palm."
    • Additionally, there are interlocking tabs securing the back plate around the edges.
    • Use the opening tool to carefully go around the phone releasing these tabs.
  3. Palm Pre Speaker Replacement: paso 3, imagen 1 de 2 Palm Pre Speaker Replacement: paso 3, imagen 2 de 2
    • Lift the metal flap marked in red to reveal the antenna connectors.
    • Carefully pry these the antennas from their connections, this can be done quite easily.
    • Take note of which colored wire is attached to each connection. The white wire corresponds to GPS, while the black wire corresponds to DIV, or diversity antenna.
  4. Palm Pre Speaker Replacement, Speaker: paso 4, imagen 1 de 3 Palm Pre Speaker Replacement, Speaker: paso 4, imagen 2 de 3 Palm Pre Speaker Replacement, Speaker: paso 4, imagen 3 de 3
    • With the backplate removed, the speaker is visible.
    • Pry out speaker with spudger.
    • It is magnetically attached so there should be a little bit of resistance; however, there are no wires to disconnect.
    • Take note of the orientation of the speaker for re-installation.
Conclusión
iDeleted
Miembro Desde 07/07/10
2,101 Reputación
39 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 303
