Saltar al contenido principal
Palm Pre 2 Motherboard Replacement
Qué necesitas
  1. Palm Pre 2 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 Palm Pre 2 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Snap off the back panel to reveal the battery using the opening tool.
  2. Palm Pre 2 Motherboard Replacement: paso 2, imagen 1 de 3 Palm Pre 2 Motherboard Replacement: paso 2, imagen 2 de 3 Palm Pre 2 Motherboard Replacement: paso 2, imagen 3 de 3
    • Pull on the tab to remove the battery.
  3. Palm Pre 2 Motherboard Replacement: paso 3, imagen 1 de 2 Palm Pre 2 Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
  4. Palm Pre 2 Motherboard Replacement: paso 4, imagen 1 de 2 Palm Pre 2 Motherboard Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas (Reference the red box in the image).
    • Use tweezers to remove the two antennas from the keypad control board.
  5. Palm Pre 2 Motherboard Replacement: paso 5, imagen 1 de 2 Palm Pre 2 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use the opening tool to pry off the (black and yellow) back frame.
  6. Palm Pre 2 Motherboard Replacement: paso 6, imagen 1 de 3 Palm Pre 2 Motherboard Replacement: paso 6, imagen 2 de 3 Palm Pre 2 Motherboard Replacement: paso 6, imagen 3 de 3
    • Use the opening tool to remove the panel on the main part of the phone.
    • Use the tweezers to get access to remove the panel giving access to the cable connectors.
    • Remove the two ribbon cable connectors using the tweezers.
  7. Palm Pre 2 Motherboard Replacement: paso 7, imagen 1 de 1
    • Use tweezers to separate the keyboard from the phone.
  8. Palm Pre 2 Motherboard Replacement: paso 8, imagen 1 de 2 Palm Pre 2 Motherboard Replacement: paso 8, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the remaining 4 screws from the main portion of the phone.
    • Use an opening tool to remove the motherboard.
Conclusión
Cole Simmerman
Miembro Desde 01/08/18
160 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G6, Freund Spring 2018 Miembro de IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
2 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 270
