Saltar al contenido principal
Palm IIIx Front Button Cluster Replacement
Qué necesitas
  1. Palm IIIx Front Button Cluster Replacement, Battery: paso 1, imagen 1 de 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Front Button Cluster Replacement: paso 2, imagen 1 de 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Front Button Cluster Replacement: paso 3, imagen 1 de 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: paso 4, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Front Button Cluster Replacement: paso 5, imagen 1 de 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Palm IIIx Front Button Cluster Replacement: paso 6, imagen 1 de 1
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Palm IIIx Front Button Cluster Replacement: paso 7, imagen 1 de 1
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
Conclusión
David Haskell
Miembro Desde 01/21/10
44 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 14-43, Regan Winter 2010 Miembro de Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,322
