Saltar al contenido principal
Palm IIIc Battery Replacement
Qué necesitas
  1. Palm IIIc Battery Replacement, Removing broken LCD screen: paso 1, imagen 1 de 1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Battery Replacement: paso 2, imagen 1 de 1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Battery Replacement, Remove the Front Cover: paso 3, imagen 1 de 1
    • Lay Palm IIIc face-up and remove the front cover.
    • Do this firmly but not with too much force so as to not break or disturb anything you're not supposed to.
  4. Palm IIIc Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Carefully pop out the battery, without disturbing the surroundings.
    • Prying tool will facilitate this step.
  5. Palm IIIc Battery Replacement: paso 5, imagen 1 de 1
    • Detach the wire connecting the battery to the motherboard.
  6. Palm IIIc Battery Replacement: paso 6, imagen 1 de 1
    • Attach the new battery by connecting it to the motherboard via the red wire.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 20-69, Walters Spring 2011 Miembro de Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 24
Todo El Tiempo: 4,192
