Saltar al contenido principal
Palm Centro Speakers Replacement
Qué necesitas
  1. Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: paso 1, imagen 1 de 2 Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: paso 1, imagen 2 de 2
    • Press and slide open the battery cover.
  2. Palm Centro Speakers Replacement: paso 2, imagen 1 de 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Speakers Replacement: paso 3, imagen 1 de 1
    • Phone with battery removed
  4. Palm Centro Speakers Replacement, Back Housing: paso 4, imagen 1 de 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Speakers Replacement: paso 5, imagen 1 de 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Speakers Replacement: paso 6, imagen 1 de 2 Palm Centro Speakers Replacement: paso 6, imagen 2 de 2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Speakers Replacement: paso 7, imagen 1 de 2 Palm Centro Speakers Replacement: paso 7, imagen 2 de 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Speakers Replacement: paso 8, imagen 1 de 2 Palm Centro Speakers Replacement: paso 8, imagen 2 de 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Speakers Replacement: paso 9, imagen 1 de 2 Palm Centro Speakers Replacement: paso 9, imagen 2 de 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Speakers Replacement, Logic Board: paso 10, imagen 1 de 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Speakers Replacement: paso 11, imagen 1 de 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Speakers Replacement: paso 12, imagen 1 de 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Speakers Replacement, Speakers: paso 13, imagen 1 de 3 Palm Centro Speakers Replacement, Speakers: paso 13, imagen 2 de 3 Palm Centro Speakers Replacement, Speakers: paso 13, imagen 3 de 3
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  14. Palm Centro Speakers Replacement: paso 14, imagen 1 de 1
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
Conclusión
Una persona más ha completado esta guía.
Kevin
Miembro Desde 04/12/10
31 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-49, Garner Spring 2010 Miembro de Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,470
