Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide is for the removal and replacement of the Palm Centro's screen.
  1. Press and slide open the battery cover. Press and slide open the battery cover.
    • Press and slide open the battery cover.
  2. Caution: Turn cell phone off before removing battery!
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Phone with battery removed
    • Phone with battery removed
  4. Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Lift the rubber cap at the top right to reveal the sixth screw.
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Remove the SIM card so housing can be separated. Remove the SIM card so housing can be separated.
    • Remove the SIM card so housing can be separated.
  7. Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert. Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Remove the small plastic insert at the bottom of the phone. Remove the small plastic insert at the bottom of the phone.
    • Remove the small plastic insert at the bottom of the phone.
  9. Continue with plastic pry tool all the way around the phone to remove the back housing. Continue with plastic pry tool all the way around the phone to remove the back housing.
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Separate the logic board from the case by lifting and pulling out the bottom.
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Slowly peel off the protective lining that is on the screen and keyboard.
    • Slowly peel off the protective lining that is on the screen and keyboard.
  14. Lift and slowly remove the screen from the front panel Place the new screen into the front panel
    • Lift and slowly remove the screen from the front panel
    • Place the new screen into the front panel
    • Make sure the new screen goes in under the plastic tabs for the additional memory slot door or it may not close properly once the phone is put back together.
Conclusión
3 personas más completaron esta guía.
Tony
Miembro Desde 28/04/10
10 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-49, Garner Spring 2010 Miembro de Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,785
